I have a fitting hole that has botched threads.
This is a flare fitting at the prop end of an alpha 1 trim cylinder.
I know auto zone sells a repair plug that you tap the cylinder 1/2 20, and it spins in and seals to the flare taper at the bottom and gives you the new 3/16 hose fitting(3/8-24)
These fitting are pretty long though. There is not much room on the back angled fitting of the alpha.
Has anyone used this fitting for a repair? Does it work or is there a shorter one?
I see these fittings on rebuilt cylinders.
