"I have a aq130c with 270 leg.
"I have a aq130c with 270 leg. The tilt motor on the port side does not always work. It is not working now. I tested and have power at the switch. And when switched I have power at the connection to the motor. The connection seems good and corrosion free. I am not getting any noise or movement at all.
I removed the tilt motor, it is an Arco 6223. I can't seem to get the sides off to see whats going on inside. I can get them away from the casing about 1/4inch then it snaps back. Is there a trick or do I just have to apply more pressure?
Also has anyone repaired these? Is there brushes that could be replaced?
Thanks,
Dave"
Thanks,
Dave"
