Has anyone used Alumiprep 33 a
Has anyone used Alumiprep 33 and Alodine 1201 to strip and coat their aluminum outdrive? Reading the MSDS' on these shows that their pretty hazardous and risky to use at home. Prekote is a much safer a alternative to Alodine but I'm not sure if you still need a cleaner with that first.
Here's what mercury marine says to use for several steps in repainting a sterndrive but this probably pre-dates Prekote. The Air Force went to Prekote on its jets. They try to keep the F16s out of the water as much as possible though.
3. Apply DX-533 (Alumiprep #33) to clean and condition the aluminum.
4. Apply DX-503 (Alodine #1201) brush on chemical conversion coating for aluminum.
5. The DP-40 (Epoxy Chromate Primer) mixed with DP-401 Catalyst can now be applied. A .75 mil film build is recommended.
...etc.
...etc.
