ranintothedockagain
Rebuilding the 350 in my 1980 Chris Craft 251. This is a 25' inboard, reverse rotation 275 hp 350, Raw Water Cooled and Paragon Trans.
The (rusty) manifolds I took off were the log style units with the big hump at the rear. I've seen this
style boat with center rise manifolds and that seems to be the way to go.
I have 4" flex pipes going through mufflers to the stern that I plan to extend to reach the center rise manifold.
Here are my questions on this....How to determine 3 or 4" riser ? Just go with what fits under the deck ?
What style center rise manifold to use ? I see mercruser style kits on ebay for 350's in the $475.00 range ?
Is it ok to extend the exhaust pipes using couplers and clamps - or should I plan to use new pipe ?
With a raw water cooled system and one (trans) cooler - where can I find a layout or diagram - showing thermostat housing, etc ?
And - How can I install senders for both a temp guage and a temp alarm on a 350 block ?
Thanks !
Thanks !
