Removing spark plugs from 60hp Bigfoot 4 StrokeHELP
redman91
"Need to know how to remove th
"Need to know how to remove the spark plugs from a 2005 Bigfoot, 60hp 4 stroke. What do I have to remove, and what can stay, when you remove the spark plugs. Is there a special tool to get to the plugs? Any help will be great...Thanks for the info...Dave"
"David, I'm looking at the
"David, I'm looking at the service manual (mine goes up to 2003) and unless something significantly changed there shouldn't be much to it.
Simply pull (twisting motion) the wire off and remove the plug with a spark plug wrench. Access looks to be quite easy - shouldn't have to remove anything else..."
