REMOVING PISTONS ON 50HP EVENRUDE
G
Gary G
Guest
" I have a 1983 Evenrude, 2cyl
" I have a 1983 Evenrude, 2cyl, 50hp and want to remove the pistons for re-ringing. Can I pull them without seperating the engine case?? ie. Can I just pull the head and reed cage and undo the rod bolts that way.??? "
I do not think that this repa
I do not think that this repair approach is at all feasable. First of all how are you going to hone the cylinders and keep the bearings clean? How would you keep grinding grit out of the bearings when you chamfer the ports ( sharp edges from the factory) that must be done for long engine life? How are you going to check the alignment on the connecting rods at reassembly?Best to rethink this project.
Thanks for the advice...I hav
Thanks for the advice...I have never heard of it being done that way anyway..
" I have a evinrude 50 hp mode
" I have a evinrude 50 hp model (50273c) year unknown, electric shift, I'd like wiring diagrams if possible with colour code for the control buttons for shift any help appreciated.
mark "
" Mark, 72 motor. The motor mu
" Mark, 72 motor. The motor must run to shift. Forward is no power to the solenoids.Nuetral is 12volts to the green wire and reverse is 12 volts to green and blue both at the same time. "
thanks sparky for information
thanks sparky for information.1 more thing would the motor be alright to run on unleaded fuel? Just bought this motor don't know much about it.
