Removing old gas
mfoxdm16
I bought a 9.9 Merc OB motor, and they owner used it twice two years ago, and hasn't used it since. He said there's probably old gas in the line/carb. How do I remove it? I've read that you should start the engine until it stops by itself, but is it ok to even do that with gas that old in it?
Hook up the tank line, tip the motor all the way up and pump the ball the old gas will be pushed out of the lines/carb. Tip back down and run normally.
