C
Carl Larson
Guest
Joe the last time I worked o
Joe the last time I worked on gear case I had motor off and turned it upside down and removed lower half of gear case. This time it's on pontoon in the water. Would it be easier to remove lower unit from exhaust housing? Is there anything I should look out for when removing or reinstalling? Does power head have to be removed? Also would lower unit from 1969 Johnson 25 hp work on this 1979 Evinrude 25 hp model 25952..
