hi i am about to remove my 3.0 l engine from my 1977 boat with a stringer drive. i have the carb, manifold & riser, starter, alternator, thermostat housing, coil, and fuel pump removed. i have the bolts loosened in the front mount and all the bolts in the bell housing removed except for 1. is there anything else that needs to be let go before i lift it out. are there bolts in the flywheel?? or coupler?? any help would be greatly appreciated.
thanks
thanks
