astroglass_81
"Alrightythen, removed stator
"Alrightythen, removed stator & repaired charge coil wires. I did check resistance from blue, red, blue/white, & red/white to ground (stator mounting ring, had stator laying on table) and I did get resistance readings. Ain't I supposed to get readings from those wires to ground? I don't remember getting a reading to ground from the two yellow charge coil wires, I don't think I'm supposed to on them two. Anyhow, today I put that sucker back on and did a DVA test on the trigger wires with the cranking motor. Spark plugs were in, plug wires were on my spark tester, & battery had a good charge. Chart said all 3 trigger tests were supposed to be 4v or more. Mine were about 3.6v on each test. Is that ok or does it need to be more? When I first did a spark test on this engine, I had the spark gap set at 1/4" and the spark looked kinda red or orange (color blind) Is the spark supposed to be hot blue? Is 1/4" gap ok? Thanks in advance for any help."
