I agree with racerone's last comment about the Johnson and Evinrude outboards. I've owned 5 and they all have been wonderful. Everything on this engine has been straight forward but removing the power head. But I've finally uncovered the mystery. You do have to remove the tiller swivel to access the last Power head bolt holding down the front of the assembly. I still can't attach jpg pictures but I'll describe the process using the parts diagram provided in MarineEngine.com. To start, remove the lower rubber shock assemblies (within part 21) and the nuts for the upper rubber rubber shock supports (part 12). The tiller assembly is now somewhat loose, but you can't remove it; it's being restrained by part 33 another rubber support. To disconnect that, loosen nut (part 32) with a 9/16 socket. The support threads is on a slot so it will easily pull out downward. The tiller swivel can now be removed. With it removed, you'll see the front power head bolt with very easy access. It's a Phillips headed machine screw on my engine but it's clear it had removed previously so it may have been substituted for a normal headed bolt. It's not hard to do if you know it's needed to be done.
