Relocating telltale hose
bw94
"I was told to relocate the te
"I was told to relocate the telltale hose to the top of the cylinder block due to possible overheating issues, but that would require to drill and tap a hole in the block. not to crazy about the idea of drilling into the block. has anyone had to do this. model# TE70TLCE"
thanks jwbmarine. I'm just
thanks jwbmarine. I'm just worried about getting the shavings inside the cooling block.
"use a moderate amount of grea
"use a moderate amount of grease on drill bit,..then stick a vacuum cleaner hose over hole......bingo."
