searcyfarms
"Hey guys, just ran into uniqu
"Hey guys, just ran into unique situation. My Boat is a 1984 Mercruiser. It had an Alpha Cased Lower Unit but had a preload pin on the upper drive shaft which they tell me was only done possibly during that year as they transitioned. I took my bad lower unit off and took it to a guy to tear down and rebuild with parts from another donor alpha ( type 1 ) unit but he said that the parts would not interchange because of the preload shaft etc...... SO I found an older style pre alpha lower unit with the preload pin ( used and not leaking, gears sound okay, oil looks fine and no metal residue ) that I am going to attempt to install. Is there any trick to installing them? It appears just getting the splines to line up and making sure the o-ring where the oil goes up the passage way to the upper part of the lower unit. I plan to replace the impeller as well. Does it make any difference what gear it is in - forward or reverse.
I did get to see the parts from my old unit and it had about 4 teeth gone on the forward ring gear. Of course there were damaged areas on the pinion gear but it was not terrible or chipped/broken.
Any tips would be appreciated.
thanks all,
Robert"
thanks all,
Robert"
