vandenburgh
I was thinking about repairing my leaky vintage 6gal original omc fuel tank for use with my 63 Johnson (I had been using motor with new plastic 6gal tank, but would like a 2nd tank for longer trips). Tank seems to leak near connection assembly at tank when it builds pressure in tank(pressure in tank, not in fuel line, doesn't leak simply when bulb is hard, but when vapor pressure in tank is building). I think it is a bad gasket (part #5 in diagram). So I was going to replace that, but figured I should probably also replace part #12, and #17 (need 2), given ethanol content in gas/potentially degraded old rubber. Maybe also hand cut a new gasket for fuel cap?
http://www.marineengine.com/parts/j...&manufacturer=Johnson§ion=Fuel+Tank+Group
my question is does this sound like a good plan? Given parts shipping cost & transit time/assembly time, would like to replace all suspect parts at once as they are relatively cheap parts. Does anyone have experience fixing these tanks and thoughts on which parts tend to fail on the old tanks? Also, how do the old metal tanks generally perform vs new plastic ones, pros/cons of old (assuming it is repairable) vs new? I like price of repairing old if it only needs $10-15 worth of parts vs $50for a new one. Comments?
