redo radar arch... splice northstar gps wire
slauder
The old furno backup has removeable end, but the NS is large plastic ends.
I think 3/4 inch hole is as large asa I can go... Is this splice-able
Should be able to get a new solder on end. I'd have it in hand before cutting anything.
If you've worked with hookup wire and mini coax before, the splice process or connector replacement should be straight forward. Most GPS antennae have a LNA in their base - these normally get powered thru the signal coax.
