red band 100 bad spark
Rod Baker
ok boys n girls a mate of mine had a battery cable fall of while his motor was running just how i do not know
it is a red band 100 6 cylinder it has intermittent spark will spark once or twice when you first start cranking then again when you release the key but no spark in between .
i am thinking it is the trigger unit inside the distributor any advice would be great
we think it is a 74 model
It is definitly not a 74 model !!!!!!!!!--------71 was the last year for " red trim " on these motors.-------------------Have you tried to charge the battery ??---------Do that and try again.
Lots of motors sold that are represented as being newer than they really are. Most common is 8 / 10 years.-------Serial # helps determine year or compare decals and trim found on -------nymarine ---------website.--------------Ignition trouble shooting guide can be found on -----------cdi electronics --------website.
71 was the last year of red " band " trim !!-------------Try inspecting / cleaning the distributor cap---------Do not force any parts as they are expensive.
ok all im really appreciative of all the help it has a large cdi in front of the carby and 3 wires into the distributor havent got the serial handy will get it tomorrow
