P
Paul V.
Guest
"I'm having some electrica
"I'm having some electrical problems on a "new" old boat I just bought. This is my first boat and I'm still learning... It pops a starter motor fuse as soon as I connect it to the battery, I mean instantly. I checked and bought the right type fuses (SFE 20A) and replaced the solenoid, ignition switch and a voltage regulator--none of these things made a difference. I also bought a triangular/diamond shaped rectifier that is specked for the serial number, but I can't seem to find it anywhere on the engine... I have a generic SELOC repair manual for Mercury/Mariner engines but it does not show a physical location of it. Any idea where I might find it? The only place I haven't looked yet is under the flywheel it seems unless I'm staring right at it... can it be under the flywheel?
My Engine is 1995 Mercury Outboard, 2-stroke, 3-cyl, model# 90ELPTO.
Thanks in advance.
-Paul"
Thanks in advance.
-Paul"
