fiddlegeek
I bought this engine this summer and it was running well when I bought it. The remote was broken (ignition still working, but shifter broken), so I bought a new one and installed it. It started fine, but when it came time to kill the engine, it wouldn't shut off - I had gotten the flameout wire hooked up incorrectly. I let it run for a while, and then choked it out. It hasn't started since. I've put in new spark plugs and tested for spark. Compression is a little low maybe but I haven't been able to test after the engine has been warmed up. The carbs were a little leaky, so I've put in new fuel pump/ gaskets and fuel lines and cleaned the carb and bought fresh non-ethanol fuel. I even hooked up the old remote as I knew the ignition/ wiring to be working on that remote. I've checked for blown fuses. I've disconnected the flameout wire at the engine. The engine cranks, but doesn't even cough or try to start anymore. I'm super frustrated (and my kids too!). What happened? What am I missing? I could really use some help!
