I just rebuilt a 1974 15 HP Evinrude and it is not staying cool even with a new thermostat I just installed tonight. I tested the thermostat and it is opening around 140°-145°. I know it is pumping good water up to the thermostat because I pulled it out along with the cover plate and started it for second and it bubbled out a lot of water. I also know the water was getting to the top of the inside of the exhaust cover because I had a small water leak. After I let the motor run for a bit it slowly started spraying a small mist of water out of the telltale on the back below powerhead on exhaust housing but the head is still too hot to touch more then a second or two so I shut it down. I just went through the whole powerhead with a new set of gaskets and seals and made sure there was no corrosion blocking waterways.
Any ideas what could be the issue?
Thanks.
Thanks.
