"I tore down one of my aq130c&
"I tore down one of my aq130c's because of compression loss in one cylinder. It turns out one of the rod bearings was gone (or at least ground up into little bits). I took the head and crankshaft/pistons to the machine shop. It looks like I will get away with new seats, a new rod and bearing and a little crankshaft work.
Its been a real lesson tearing apart the engine, hopefully putting it together wont be too eventfull. I have never done any engine work before, but its pretty straightforward.
It looks like the engine was blue at one time. Does anyone know what the orig color was (1969)? I like the blue color but my other engine is red, I may redo that one next winter. I asked my wife and she said noone sees it, what difference does it make? Women, they don't understand the importance of such things as boats and motors.
One other question, the oil pan is indented at each of the bolt holes (from tightening). Is this a problem or will the gasket seal this. I lost oil in the engine with little use. And is the oil pan from the auto engine the same?
thanks,
Dave
bearing shrapnel"">
before removal
thanks,
Dave
