Rebuilding carbs
bw94
"If I rebuild or take apart th
"If I rebuild or take apart the carbs to clean,would i have to have the carbs re-synced"
"As long as you do not change
"As long as you do not change the linkage adjustments, you will not. Make notes, take a few pictures before removing them."
"some carbs,have diff high spe
"some carbs,have diff high speed jets...always put carbs back,where they came from....and some,have u to back that way....older style or they would not mech work."
"I took the black plastic ones
"I took the black plastic ones off the face of the motor, they have the float bowl on them. I did not mark which one came off which cyl so chances are after I cleaned them, they did not go back on the same cyl they came off. When I took the boat out, it would not get up on plane. there was NO hole shot.
Is there a way to know which one goes where?"
"Please post the Year, Make an
"Please post the Year, Make and Model will help, since its in the manual based on the size of the orifices PORT and Starboard on mine is different on the idle and intermediate"
"Looking at the parts diagram
"Looking at the parts diagram for that motor I can't see where the orifices are any different, but that doesn't mean anything.. ;) Hopefully one of the other more knowledgable folks will be able to help..."
Looking at the diagram ? Remov
Looking at the diagram ? Remove the orifice and look at the stamped number on the side of it a diagram will NEVER show you the size it simply tells you what it is.
