arild_johannessen
Hi
Have just got my hands in an old engine that I just finished disassembled.
Need some advice when it comes to clean the carboned pistons,rings are stuck.
Can I use pistons from a 105 hp,bore size should be the same,but are the
crankshaft and rod bearing the same?
70hp- piston with three rings
105hp- piston with only two rings* (can theese be used at all in this engine?)
Any things I should do while the I have the*engine disassembled?
