In replacing the impeller in rwp noticed the package came with just a rubber o-ring instead of the paper gasket. The part number matched but not sure why rubber gasket instead of paper one. Well was in a pinch so used the rubber gasket and a spare paper gasket that was close but not exactly the right one (little too wide in one area) and not leaking but not sure is right. Someone said that rubber gsket is for a newer style pump that has groove which mine does not.
The part number used was 20300 which was just impeller and rubber gasket. How can tell if is OK or should take apart and get right paper gasket? Seems to be flowing good water.
Long story short, not sure if is right as overheat problem still there but could also be something else.
