Thunder Monkey
I am new to the forum and also new to attempting to fix an outboard. I have a 1988 50 horse force that when I got it had a hole in the top piston. I tore it down cleaned it out really well and cleaned up the cylinder to remove any of the piston material that was on the cylinder wall from the piston. I ended up locatig a used pistion on ebay and put new rings in it and put it back together with all new gaskets and torqued to spec. When trying to turn it over by hand it will turn fairly well with a little effort, but with the starter it is either slow or wont turn it. My starter was bad so i replaced it with a used one from bay from a seller i have bought from before. I am confident he sold me a good stater, is it possibly too tight? Should I take it back apart an have the cylinders bored ?
