" I bought a 1976 Bertram 35 t
" I bought a 1976 Bertram 35 this year that has original Mercruiser 350HP 454's with about 1100 hours each, fresh water operation only. Both engines start and run smoothly, with minimal smoke and only a little oil slick seen after idling for several minutes. Both engines reach 4500 rpm easily with similar throttle settings.
One piston has compression about 115psi, others all 130-150, so I am thinking of doing an overhaul to see what's up with that piston (ring problem, I think).
What should a "major" on these engines and VelvetDrive transmissions cost? Does it make sense to rebuild engines this old? Are there parts available for 1976 Velvet Drive transmissions? What would you do? "
