I found water in the lower uni
I found water in the lower unit so we took it apart to fix. Replaced the drive shaft bearing and 2 prop shaft bearings. Had to clean off the fwd and rev. gears that were covered with crud. Cleaned off the clutch dog assembly and cleaned off the pinion gear and found that it is not bolted to the drive shaft what’s up with that? anyone done this before? When I replaced the drive shaft bearing I found it hard to figure exactly where to set it on the drive shaft. There was a clean mark on the shaft where the old one was so I pressed the new one to that spot. I replaced the water pump and now I am ready to attach the lower unit to the power head.
I can see that the drive shaft moves up and down about .050 is that normal I wonder. I bought a Clymer manual for 30$ and I will send it back it shows very little about this procedure. sorry so long
Gary
Gary
