Hi,Guyies I am in qustion on a couplle of things.First off there are 3 bearings 1 upper driveshaft bearing 1 lower driveshaft bearing 1 bearing in the oilpump.Should i use a molly grease for the driveshaft upper + lower bearings?And the pump bearing does that get grease or does the type c gear oil lube this pump bearing? Allso should I use grease on the thrust washers and thrust bearings ?Looking for any helpfull hints with this reasemble.Thanks Tony
