gpavkovick7868
0A509551 3.0L 0A496660 ALPHA 1
CAN I REPLACE MY REAR ENGINE MOUNTS (DOUBLE WOUND LOCK WASHER/REINFORCED WASHER SYSTEM) WITH THE (ONE PIECE RUBBER MOUNT SLEEVE AND SPACER SYSTEM) ? Is the spring washer system adequate? This is my first post, I want to order several parts from marine engine.com and the parts ordering catalog shows the integral mounts in the flywheel housing view and shows the spring washer mounts system in the in the transom plate view. Parts dept. does not know.
