In my other posts I’ve been trying to diagnose a backfireong spluttering noise and a very violent shake just a bit so happy outboard. At first it would start as I manually put the revs with my hand on the throttle inside the motor when we were out on the water to as high as they go and it would kick over but just die. Now after reconditioned the carbs fuel pump and had a look over of the other parts i got it to start at home but still doing it just not dying . This is what I’ve found pls help or ask questions
the thing is nothing , all in immaculate condition and no faults only thing I can see is on the throttle part where the is a spring so as you increase throttle the spring carry’s the timing that is connected to the stator along, this has two scenarios one where you increase throttle and the timing stays in position and then at a certain amount of throttle it jumps over or catches up as such or scenario two it is as such connected to or follows the throttle in sync so as increasing throttle it slowly increases with it until at max the thing is I’m not sure which one is correct so I don’t know how to fix it if anyone knows which one it should be doing would be great.
My guess is at this point I need to do a full synchronisation of the ignition and fuel and timing systems as it has never beee done by me while I have had it and I suspect previous owner, I have checked plugs and they are sparking but not sure top cylinder might not be getting as much fuel or is that just a common occurrence as it is at the top and not laying in excess fuel like The bottom one , I also bought new spark plugs to test them but not really liking them it has started with them but only when the engine was really hot I think it just doesn’t like new plugs but I looked online and the plugs that were in there weren’t the recommended ones by the Manuel if it is running on them though should I still change them or just stick with it
