I will need some help with some Idle and WOT timing for my 1999 Force 120 hp outboard. The manual says static 32-30 degrees BTDC and nothing about Idle? I have been using the Idle advance bolt & set screw to make Idle RPM. Little did I know the timing advance ss bolt and set nut were loose and changing each time out. I have TDC #1 at ZERO. What the heck should the IDLE timing at 800RPM be? I know how to set the advance at static WOT but what about the IDLE?
