Roastmedaddy420
Gday folks.
I feel like I have committed the sin of complacency and didn't care to understand what I was doing well enough and am now paying for it so I'm here for the roasting.
So basically I was having an idle problem with the boat in the water with it stalling but high throttle was maintaining (albeit not reaching the spec top speed). So I advanced the idle stop screw / timerbase to increase idle speed, however I advanced it to an extent that minimised how open I could get the carb throttle plates, but I figured I was okay with a lower top speed if it didn't cut out at idle. Why it wouldn't idle where the timer base is supposed to roughly be I don't know, I've narrowed it down to some kind of spark problem because I've made sure fuel supply is good and carbs are clean & correctly assembled. I thought advancing the timer base just meant more revs, but I think I'm realising it is supposed to be in harmony with the throttle openness? someone correct me on this
So anyway I was cruising for about 10-20 minutes at like half throttle (Which wouldve fully advanced the timer base), and then it just died instantly (after some gradual jerking) and now I can't get it to kick over.
I'm doing a compression check as soon as I can borrow my mates tool, but is there a chance the sudden stall threw the timing out of whack (and therefore it won't kick over) or have I just cooked my motor? It still feels like it has compression when I turn the flywheel & listen to the spark plug holes
Roasts are welcome
Motor is a 1997 evinrude 3 cylinder 2 stroke by the way.
Roasts are welcome
