Mt friend and I inherited a nice rd26 40hp 1964 engine. Apparently it ran 2~3 years ago but might be missing a water or fuel pump. When we pull the start cord there is good compression and its really hard to pull. Not sure if that is normal. It was just the engine so we are not sure if we need to put a start stop switch somewhere. There us a cable that is ground and goes to a connector. It might be rpm or start? Is there anything we can safely take off to inspect. I have good electric knowledge so if I can get to the coil and generator I would test and replace the lot if needed. I know the flywheel has to be torqued but I am not sure where it is. What could you advise for us to check and try and start it. If need be we got a spe******t in Manchester that could service it but can we do something? The engine was covered well. Nothing is rusted and it seems to work well. The gears go in and out.
