"I've used thru hulls on a
"I've used thru hulls on all my boats. It is unlikely that you will find a raw water filter that will filter out mud. Even if it did, it would plug up just about as fast as your oil cooler did. The big benefit of the thru hull is that it is (or should) be mounted well forward of the transom. On my boats over the years(one 18 ft Deep V and two 23 ft Deep V) I mounted the thru hull intakes in line or very slightly ahead of the front of the engine off to one side (typically to port, but thats just how clearances worked out). At this location, even if your prop stirs up muck, you have a fighting chance of not getting it in your engine intake in the first place. One caveat... if your hull is a deep V or even a moderate V and capable of 25+ mph speeds, the proper orientation of the thru hull scoop is NOT straight forward, but rather "toed in" at bit. Water flow when the boat is on a plane in the area of your new inlet is not straight fore/aft but rather flows in an angle from the keel outward and back. Recommend that you use all bronze fittings and that the shutoff valve be a 1/4 turn ball valve, NEVER as gate valve. Also... be sure to have a backing plate (Star-board material or epoxy saturated exterior plywood works well for this) inside the hull. Be sure to use bedding compound between the plate and hull. This is strongly recommended if you elect to use the screw holes on the "scoop". You want the screws to reach into the backing plate. DO NOT SCREW into the hull from the outside and only bite into fiberglass. I've also noted that some scoops "new from the factory" have rather sloppy "grills" from not having the casting flashing trimmed off. Some time with a small file or Dremel tool to make the inlet grills smooth for improved water flow while possible not strictly necessary has always left me feeling better. IF Zebra mussels are a problem in your area, make sure that the inlet that you buy has an access port so you can "roto-rooter" the inlet pipe...not all raw water inlets have this feature. If you do your own winterizing, install a "T" fitting and another valve (hose bib) just after the thru hull shutoff. This will allow you to just hook up a hose to the valve, and stick it in a bucket of antifeeze. ( Shut off thru hull, open flush valve)"
