Ahenderson
HI ALL, I am looking for some help. I recently arrived at my boat (1982 Searay overnighter - I/O) to find it full of water... bad day... Contacted the insurance company and sent it to the shop who tested and sourced the issue to the raw water pump. We had the boat serviced 4 months ago and the mechanic specifically tested the water pump and reported whilst she repaired the impeller, wear plate gaskets and other components. The insurance company is saying that the raw water pump bearing seal wore and allowed water to enter resulting in corrosion. They are therefore saying that it is a wear and tear item and therefore not covered by insurance. My view is that as a boat owner, i did everything that was reasonable as a responsible boat owner (i.e. spring full service including water pump) and that the work should be covered. The mechanic who did the work in the spring insists that there was no issue with the pump beyond what was repaired in the spring. Does anyone know under what circumstances this damage could have occurred over the last 4 months other than wear and tear? I can't understand it! Thanks in advance!
