Could some of you folks tell me how much resistence there should be when trying to turn the raw water pulley by hand with the belt disconnected on a 1987 big Block Crusader? I see on the back and front of the shaft where water has been leaking and I suspect some wear and maybe some play in that area but do not know if this is normal. Also, is there a special procedure for removing the impeller? Thanks
