After removing the impeller of
After removing the impeller of my raw water pump I found numerous screw driver dig marks on the inside casing as well as hammer marks and some deformities on the shaft itself. I purchased a new Sherwood E35 pump rather than rebuild the old one for peace of mind..Now the problem.. The hub where the pulley bolts on is larger in dia. as well as in thickness. I found a new pulley at the marine shop that fit. When I mounted the pump the pulleys where out of alignment aprox 3/16 of an inch off over a short run. You could see the belt angle off the top of the pulley. I cannot get any fore and aft adjustment only side to side. The pump is a pedestal style mount and mount is slotted for only side to side play. I pressed the hubs off the new pump and the old pump to swap however the hub on the old pump pressed on to the new pump shaft with very little pressure vs the amount of pressure to remove the hub that came with it. Im afraid that with the torque of the engine the hub will spin or spin off. The new hub is twice the thickness of the old pump hub. Im thinking of taking the new hub to the machine shop and having them take off 1/8th of an inch from both sides of the hub or all 1/4 inch off of one side and have the hub pressed deeper on the shaft. Anyone else have this situation??? Both pumps are the same Sherwoods however the old pump is circa 1966 hub changed in 43years. Cast iron pully to modern stamped steel.
