Raw water pump replacement
Saltshaker
Hi all I need a new water pump and was told mine is a proprietary Pleasurecraft Part number ra 057031.
I'm going to try to have it rebuilt. Any thoughts on where to get a replacement if I need to?
thank you.
If this is the PCM RA057031........
..... it's nothing more than a belt driven Sherwood sea water pump, w/ PCM's p/n being used.
If the the impeller thrust surface is OK, these can be over-hauled.
Product Details
Pleasurecraft Model Mitsubishi 4 Cyl Engine Model: Mitsubishi 4 Cyl Engine Part Number: Pump Availability: Active Sherwood Replacement Pump: G22 Impeller Kit: 09959K Minor Repair Kit: 23979 Major Repair Kit: 12665 Inlet Port: Outlet Port:
Read more: http://www.monstermarketplace.com/m...013-pump-assy-r-w-4140-w-pulley#ixzz2TND996ff
thank you, that looks a little different. when he went to pick up the new pump, i guess it was physcially different and thats when they started researching it. is that the exact pump in your pic? does it have a plate to remove the impeller? maybe I'm looking at different place on the motor itself. ill see if i can post a pic.
Thanks I'm not sure what happened today but apparently the part on my 454 is a $700 pump and only in Florida. Serious?
tomorrow my friend is going to take it the shop to see if the rebuild it.
