"I'm completing an engine
"I'm completing an engine rebuild. When I started it the first time, with a flush device on I/O that I've used many times, engine quickly overheated. Shut down and found risers dry and rubber exhaust tubes smoking. Engine registered 190 when I shut down after 3-4 min. running. Checked everything re plugged lines etc, and all ok. Pulled outlet hose of raw water pump and impeller looked good and would push water when I filled inlet line and turned pump by hand. THEN I discovered I'd never tightened the pulley bolts! However, when reassembled and cranked engine w/ coil wire off, it wouldn't pump any water. Don't really want to risk starting it again and overheating it. So my question is (yeh, finally) should the raw water pump draw water up from I/O flush device and into engine when only cranking?"
