Hi, making progress on my refit and trying to do some plumbing updates. The boat has 2 raw water pickups, look like 1.5in size. The outside has a strainer (rivets to the thru hull fitting) as it comes thru the hull, it has a wood backing plate and the seacock attached to it. The seacock has a flange for 2 (screws?) to the backing plate. It had only 1 screw holding it. How is the thru hull fitting attached to the seacock? Is it threaded into the seacock? I'm thinking either when the boat was made they tightened the seacock onto the thru hull and just used screws into the backing plate to keep it from turning. The backing plate is painted the same color as the bilges so it appears original.
I rather not use a sawzall to remove the seacock, as I know these can be serviced. I'm going to replace them and the backing board, but would like to save the old and either resell to someone looking for parts.
I'll take a picture of what I have.
