disasters are always a series of events..... let me know what you guys think.
I changed all of my transmission lines last fall and ran the engines one more time to test all the connections. I forgot to tighten the lower most hose and a lot of the fluid leaked out while idling.
Well, fast forward to this year and I completely forgot about that. I started the engines for the first time about two weeks ago and they ran fine. The shaft was turning but I didn't give it much thought because I didn't have the prop installed and figured the extra drag wasn't there to keep it stationary or close enough, barely turning. It idled for about 10-15 mins but never put in gear.
Installed my new alternator last night and figured I make sure that's ok since I'm supposed to go in next weekend. The engine is turning over and making this horrible dry pump sound. I figured it had to something with the alternator so I disconnected that and same thing. It's turning over, doesn't really want to start and making the noise.
Then I pull the dispstick and it's bone dry. I add some fluid, get it running and it's still making the noise and the shaft is spinning at a pretty good clip. Do this two more times, adding fluid and finally get it to where the noise has pretty much stopped and the shaft isn't rotating in neutral anymore. I tried it in reverse and forward and it goes into both gears but I still hear an occassional noise (not continuous) of that dry pump sound.
Since I just did the strut, I knew exactly how the prop should feel when rotating by hand and it's exactly as it was before which is good. It's definitely not seized up but I'm not sure if the sound will completely go away or get worse under load. It's got the right amount of fluid now and the noise is 95% gone... again all on the hard, at idle. It does make the noise more if I bring the idle up but again not continous like when I first started it. I assume it's the pump I heard and ran dry... is that fatal? Fluid is nice and pink but it's about 5 mins old too
Am I toast or should I just run and see how it sounds? I guess if I had to pull it, I would rather be in the water doing the work. Do the pumps cavitate for a while when run dry?
BTW, new alt works just fine.
Bob
Bob
