Racor filter changed and I don't think I did it correctly. Done a couple weeks ago and wont start now.
General fuel intake plumbing:
Single 260 gal tank with port and starboard lines (soft rubberized) to Racor .2 mill filters, same soft lines to Flowscans, same soft lines to pump, metal lines to 20 mill sierra separator, and again metal lines to quad-jets.
Observations:
1. Fresh 200 gals gas at marine gas dock (oct 93) three weeks ago.
2. The Racor was drained and I didn't fill her up when I put new filter in. Maybe part of the problem?
3. I opened Racor yesterday and she was still dry and the inside gasket looked larger then it was when I put it in.
4. I opened up the 20 mill seperator and it only was half full.
5. The Racors were painted with some brown rubber type paint years ago (part of a rebuild?) and some peels are occurring. It was painted outside and inside on the metal parts. thinking a peel could clog up the line.
In the limited time I had, these are the actions I performed:
a. Filled the Racor to top and closed.
b. Turned over the engine for 40-50 cranks. She would not start.
c. Opened the 20 mill separators (they are after the pump) and still only half full. Noticed a problem with the rubber gasket in the sierra separators. It popped out and now seems too large to pop back in. Can I get these rubber gaskets to shrink?
What to try now? My thoughts:
I. fill a new sierra separators up completely and replace other new one that has issues with larger gasket popping off.
II. fill carb bowl with a syringe and try again to verify engine starts okay.
Also, I have a vacuum tester but not sure how to use it to test pump if need to. When I had someone install the flowscans they used somekind of glue as well as the clamps. I have never taken off the soft hoses from the barbs they connected to.
Wondering about a possible clog. How to fix that if its the rubberized paint that peeled or something else clogged line. do I need to blow out lines with air?
Observations:
