ChaumontBoat
I have a 2004 Yamaha 60. Recently it started quitting whenever I am in neutral at idle. It will start good at idle and run for about 20-30 seconds then quit. If I increase throttle in neutral it will stay running, but if I increase the idle adjustment (I had it up to 1200 RPM) it will still quit when I shift to neutral. Yet if I throttle to 1200 RPM in neutral it will stay running.
It runs fine in gear even at low speed and starts easily in neutral at idle.
I've checked the fuel filter and did the link adjustment on the carburetors (I have the service manual) and have played with the idle adjustment screw.
I've also replaced the spark plugs.
