I have just bought a boat. It is a 21' Sylvan Pro Fisherman with Merc 115 outboard on it. The outboard is the older style from early 90's. I can't read the id number as it has been scratched. I took it out for a water test and it ran great.
I decided to give it full throttle to see how she would handle. The water was a little choppy. All of a sudden the alarm on the Quicksilver throttle started beeping. I stopped and checked the oil. It was a little less than 1/3 full. I added what I had and brought it just over half. The alarm would not shut off. I thought maybe because of the rough water it thought the oil was low. It is not a constant tone but a steady beeping.
After sitting so the engine was cool and oil had settled I turned the key again. The alarm still keeps beeping. I traced the wiring to the outboard. When I disconnected the purple wire to the oil warning module it stopped beeping. Reconnect and the beeping continues. I tried disconnecting the battery and reconnecting but that did not reset anything.
I am wondering if I should replace the oil warning module. The part is not serviceable. I checked all the wires for corrosion or bad grounds but this engine is spotless. The part number (for the module) is 14857A14. Replacement part is 144-4857-16. I would appreciate any suggestions. I read something about an oil reserve that can be lossened to allow it to refill but I don't know if this applies to my motor.
