"[b]Morten[/b], so either 1 or
"Morten, so either 1 or 2 will do the job on disabling the QSF (quick start feature) and then be able to do the WOT max spark timing or do I need to do both 1 and 2 at the same time?
I’m trying to set my max spark timing by the Joe Reeves method, I notice that from the switch on the cylinder head there is a black/white wire as you stated, but it connects in to a brown wire (at least looks brown) that goes to the power pack, for method #2 grounding the wire coming from the switch itself won't do anything right?, I need to ground the wire that come from the power pack itself right???
If only one of the two methods is needed to disable the QSF and I’m understanding right it is much easier to do the #1 method…"
