Andyspoppa
Hi all,
New to this Boating thing...am a mechanic by trade (aircraft).
Bought a used boat...18 Ft Wellcraft, with a Merc-cruiser (GM 4 Cyl) 165 HP, and an Alpha Drive. First time out it spit through carb when trying to advance the throttle ...but settled down after warm up. Ran fine...but pulled to left and was a nightmare to hold straight at high speed...had to hold it to the right hard. Found the node tab was pointed way over to the right (looking from prop fowrard) I moved it toward the left just a little from center...need to see if that helped.
Removed the prop to lube the shaft...put it back on, but evidently not right, as when I tested it this morning in the lake...it wouldn't propel the boat either way! Got it out of the water and looked to see what was wrong...nut wasn't down enough! By using a board to keep the prop from turning for loosening the nut, I left it in place to tighten it!! Wrong move...retighten it and put it back in the water, started it up, put the tilt down, engaged the drive in Reverse...wouldn't move the boat at all. Tried fwd...moved??
Talked to a guy at the marina...he said it sounded like the drive wasn't engaging...and told me it was adjustable at the cables.
Sorry...for the long read...but is that sound right? nd one other thing, it has a closed cooling system, do I still have to get those ears to put on the foot when cranking it up?? I had an outboard once and had to use those...but not sure on a closed system.
Thanks in advance...
Andyspoppa
Andyspoppa
