NaymzJaymz
Hello Friends,
I've located a older used 25 HP Evinrude 2 stroke motor for sale at a reasonable price. I believe it is a early 80's tiller unit. I'm going to go look at it to see about buying it. The seller said it ran great and had great compression before being garaged. I could sure use some advice from some of you experienced guys on how to evaluate an older used motor like this. The seller says I'll have to bring my own gas if I was to hear the motor run, so what mixture of fuel should I take? Is there any difference between a gas tank for a 2 stroke than that of a 4 stroke? I've seen in some forums that some guys advocate running a richer mixture for the first gallon or so to make sure crankcase is well lubricated. How about a compression test? Will a typical automotive compression tester work? Any spark test? Sorry to go on and on, guys! Please help. Thanks!!!!!
