Hi Y'all
I am rebuilding a 2002 2 stroke 140 hp Tohatsu. Bored to oversize, new pistons and stuff
2 questions
Float height: I am having trouble adjusting the float height. With the carbs inverted it should be 19,5 mm from carb surface to top (bottom) of float. But it is not possible to adjust the height of the float by adjusting the clip. Since the rests on the needle valve when inverted. Any tips?
Oilpump: I am thinking of bypassing the oilpump. I havent got a new oilpump. I know that engine is constructed to use oil pump, but could I remove it? And motor still runs with a bit more smoke perhaps.
2 questions
