"Can get forward or reverse, b
"Can get forward or reverse, but can not get enough throw to get both. Have about 1" of travel in shifter cable on bracket at the motor. Both ends of shifter cable (red) are adjusted all the way in...can not take up any more slack. Moved the shifter cable to the top of the shifter bracket to get max throw. I initially adjusted the outdrive according to Stuart Hasting's 5 step method.
My initial impressions are:
1. Lower unit is worn to the point there is too much distance between "F" and "R" on the shifter lever. I have a new lower unit (not installed yet) that seems to have much less travel between Forward and Reverse.
2. My shifter/throttle (at the front of the boat...controls??)is worn. This seems to be where the shifter cable play comes from.
My questions are:
1. Is it possible for the lower unit to be worn enough that you can no longer get both gears?
2. Can the controls/shifter be adjusted to take out this slack, or should it be replaced?
3. If it needs to be replaced, where can I get one.
Thanks in advance folks. I am at work...remote...and am deciding if I need to order some parts to be home when I get there."
My questions are:
