"Sorry for the multiple posts
"Sorry for the multiple posts today, but now that I got the engine running, I have am starting to work through the rest of the problems. Here we go:
The AQ130D has dual carbs. When setting them up after being rebuilt, i was able to get the carbs synced and the linkage adjusted relative to the throttle/shifter(helm) control so that it idled when the lever was straight up and so that it would shift into forward at a reasonable RPM. However, reverse is another story. When attempting to move the helm lever backwards to engage reverse, I noticed that the throttle cable was trying to push the carb linkage in the opposite direction(up). If I were to push hard enough it would likely bend the linkage where it bolts ot the carbs.
For now I adjusted the linkage at the cable and at the outdrive so that it goes into forward and I just do not have reverse. This, obviously, sucks. How is this supposed to function? I would think that something in the helm would allow for the application of throttle while in reverse. Is my helm busted?
As I understand it, there are two seperate cables going to the helm--one for throttle and one for gear. Could I just hook it up to a dual helm that separated the two, or is there a simple part that needs fixed on my helm? I have looked everywhere and I cannot find a diagram of how my helm works. Some explanation of how it is supposed to work would be most helpful.
Thanks!"
Thanks!"
