motorcyclefanatic
I purchased a Hydrostream Valero recently with a mid-80's 2.4 Merc V6. The boat seems to run fine, if not a little fat in the mid-range.
I decided to pull the carbs and do a cleaning and see what was inside. It has WH22 carbs which run 74 & 76 mains and 46 idle jets stock. I found the mains had been been bumped up to 80 & 82. All the idle jets were 48. The vent jets were all stock.
The plugs all looked a little sooty, but I'm not sure how long they'd been in there. I don't have any history on the motor. It also seemed to be a little on the thirsty side. The oil injection has been removed, pre-mix @ 40:1.
I wondering what the consensus is for returning the motor to stock jetting. I don't want to seize it or hole a piston. BTW, I'm running in Florida, so no offset to the stock jetting is called for.
Thanks, John
Thanks, John
